TwinTurbo.NET: Nissan 300ZX forum - The PCV system is designed to alleviate pressure from blow
Subject The PCV system is designed to alleviate pressure from blow
Posted by Tanley (ATL) on May 08, 2022 at 9:56 AM
  This message has been viewed 377 times.
In Reply To PCV system on TT how is it enough? posted by 300zulater on May 08, 2022 at 09:45 AM
Message by. Whether running lower or higher boost pressure, there shouldn't be that much of a difference in blow by, if the engine is healthy. The main issue with the stock PCV system is the port on the exhaust side valve cover is too low and can allow oil to dump into the intake. Look up the PCV mod to correct that issue.
