TwinTurbo.NET: Nissan 300ZX forum - It should be hotter or at least the same at the rear...
Subject It should be hotter or at least the same at the rear...
Posted by Ted (92TT) on April 27, 2022 at 5:10 PM
  This message has been viewed 311 times.
In Reply To Cats should be colder in the front, hotter in the back right posted by ChrisZTT(Sacto, CA) on April 26, 2022 at 09:02 PM
Message It sounds like they weren't hot enough to activate. If 205 was F it's close to what the outlet side of the shell should be, from what I've read. 120F isn't even close to hot enough. If it was 205C it's too hot and I would think possibly clogged, but since the outlet is lower that doesn't make sense. Is your AIV working, or do you have a chip tune that disables it? The extra O2 is to help heat them, but 93 or 94 it was removed so not considered necessary. I would do a hot run and then check the temps right after to be sure the catalyst has reached its light off temperature internally.
