TwinTurbo.NET: Nissan 300ZX forum - Then you didn't fix it by removing the oem unit.
Subject Then you didn't fix it by removing the oem unit.
Posted by Bernie (NoVA) on April 26, 2022 at 10:02 AM
  This message has been viewed 351 times.
In Reply To Re: Which theft system? Oem or aftermarket? posted by Ahhsaw on April 25, 2022 at 10:54 AM
Message Your problem is not the factory antintheft.
Check your fuseable links, the rubber stopper switch on the clutch pedal and the actual ignition switch at tye steering column.
I have new oem Nissan ignition switch modules if you need that.
