TwinTurbo.NET: Nissan 300ZX forum - I had the same leaking issue 10 years ago...
Subject I had the same leaking issue 10 years ago...
Posted by YamilZ32 on April 20, 2022 at 4:24 PM
  This message has been viewed 238 times.
In Reply To Windshield Washer Tank Motors posted by MikeJ on April 20, 2022 at 01:07 PM
Message ... specifically in the hose section. which I solved replacing the leaking motor Problem is I understand this motors are NLA, so you will need to get a used one, or have the leaking place fixed by yourself. In regards the windshield washer light, make sure the fluid level is filled at least the dipstick is wet. A month ago I thought the sensor was bad and it was not, problem was that the water level was "low" as the sensor sits high. This misunderstood is normally taking place when eye inspection of some water level makes us think that should turn off the dash light when it does not.
