TwinTurbo.NET: Nissan 300ZX forum - Re: That wire key on is 2.8mV only at the pump connection
Subject Re: That wire key on is 2.8mV only at the pump connection
Posted by Cjw3 on April 16, 2022 at 2:03 PM
  This message has been viewed 262 times.
In Reply To That wire key on is 2.8mV only at the pump connection posted by Drk93TT on April 16, 2022 at 01:02 PM
Message Battery Voltage on the Orange is what feeds the Fuel Pump Controller, and the Air Regulator.
The Battery Voltage on the Orange Wire id Fed from the Battery Through a Fuseable Link next to the Battery, Off to the Fuel Pump Relay..
Check the Fuseable Links.. If you look on the ECCS you will see the Fuseables on the lower right.. It's the White Wire/Blk Stripe
Cj
