TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Electrical / Fuel pump issue
Subject Re: Re: Electrical / Fuel pump issue
Posted by Cjw3 on April 16, 2022 at 11:29 AM
  This message has been viewed 278 times.
In Reply To Re: Electrical / Fuel pump issue posted by Drk93TT on April 16, 2022 at 10:34 AM
Message Go Fine this Pic of the ECCS
[ http://www.twinturbo.net/nissan/300zx/forums/technical/view/1094626/ECCS-Wiring-Diagram-in-color.html ]
Starting at the Upper Right, you will see that the Orange Wire off the the Fuel Pump Controller, makes it way over the the Middle Upper Right of the Air Relay Orange Wire.
If you use a Test Light ( I like them Better than an Volt Meter for Fast Testing ) you should see Battery Voltage related to Ground During Cranking..
You Should also be able to PUT Battery Voltage on that wire to Get the Fuel Pump to Run..
If you have Voltage on that Orange Wire, and the Fuel Pump is not running, then it's either the Pump or the FPU.
The FPU 'Controls' the Pump Speed by Varying the Connection of the Pump to Ground.
Cj
