TwinTurbo.NET: Nissan 300ZX forum - 1.3 megaohm?
1.3 megaohm?
MixManMash
on April 10, 2022 at 8:12 PM
Also..
posted by Drk93TT
on April 10, 2022 at 10:38 AM
It should be very little resistance, like 1 ohm or less if there is good continuity to pin 23 and the white wire.
Code 34 and hesitation
Drk93TT
06:30:05 04/10/22
Ohm readings just taken
Drk93TT
08:47:07 04/10/22
Also..
Drk93TT
10:38:21 04/10/22
1.3 megaohm? -
MixManMash
20:12:30 04/10/22
Re: 1.3 megaohm?
Drk93TT
20:28:21 04/10/22
Yeah, sounds like either it wasn't making good contact, or
MixManMash
20:48:04 04/10/22
Re: Yeah, sounds like either it wasn't making good contact, or
Drk93TT
04:54:18 04/11/22
I assume you haven't mixed up the VTC connector with the one
MixManMash
14:44:15 04/10/22
Re: I assume you haven't mixed up the VTC connector with the one
Drk93TT
17:30:35 04/10/22
VTC is in the correct spot, those wires are BR & GB (n/m)
23:59:54 04/11/22
Another interesting thing / wire color Grey
Drk93TT
05:41:50 04/11/22
Update ……
Drk93TT
17:27:45 04/11/22
Corrected
Drk93TT
19:32:27 04/11/22
If they are aware of the issue - they should be checking for
00:00:52 04/12/22
You'd think. Hopefully this is an isolated incident
Drk93TT
07:12:24 04/12/22
Good to know, I need to go look at my new/used sub harness
itsa300zx
09:54:30 04/12/22
Indeed. So much for Quality Control... (n/m)
MixManMash
19:32:58 04/12/22
Wow - that is aggravating.....
Unluky (MO)
08:45:52 04/12/22
Thanks! Had the same issue on a brand new build too. (n/m)
ConVerTT
18:58:58 04/12/22
