TwinTurbo.NET: Nissan 300ZX forum - Re: Re: JWT530BB no boost past 9.5PSI with EBC
Subject Re: Re: JWT530BB no boost past 9.5PSI with EBC
Posted by reggeo on March 25, 2022 at 8:56 AM
  This message has been viewed 248 times.
In Reply To Re: JWT530BB no boost past 9.5PSI with EBC posted by Kvert on March 24, 2022 at 09:22 AM
Message When i got her back, the boost controller was set at 17PSI gain 15% but the AC/WG was marked as WG (external wastegate), so i thought this should be AC (actuator type wastegate) and changed it, but when i changed it the car wouldn't boost past 9.5PSI. I have little knowledge about this matter, and i'am afraid to drive the car because i think there is something wrong. I checked all the vacuum lignes and the wastegate actuators of the turbos are hooked up directly to the OUT port of the boost controller solenoid with a T-piece in the centre of the engine. Throttle body passenger side (not JDM) is hooked up to the In Port. Recirculation valves are still hooked up. All deletes and bypasses are done correctly. Everything is capped of pretty good.
