TwinTurbo.NET: Nissan 300ZX forum - The new door is from a 93 and my door is a 92 both are 2+0>>
Subject The new door is from a 93 and my door is a 92 both are 2+0>>
Posted by ZUL8TR on December 27, 2021 at 6:51 AM
  This message has been viewed 313 times.
In Reply To Re: You can change the lock barrel in the door handle posted by Doug71zt(CAN) on December 26, 2021 at 02:47 PM
Message will year difference be an issue with what you describe? Since I have to remove the outer door lock assembly from each door I could just replace my assembly with correct key in the new door.
Regardless you note I have to go inside each door to remove each door lock assembly to do the transfer.
Anything else you think will help do this is appreciated
Thanks for you help
ZUL8TR
