TwinTurbo.NET: Nissan 300ZX forum - Did smoke test include the engine. Intake leak check.
mrchips
on October 31, 2021 at 6:38 AM
Updates: Tried a few more things today.
posted by Woody75 (Denver)
on October 30, 2021 at 11:47 AM
Need help with low rpm engine stumble issue.
Woody75 (Denver)
18:06:17 10/26/21
Re: Need help with low rpm engine stumble issue.
Metacom
19:42:01 10/26/21
Also...
Metacom
19:54:47 10/26/21
Aftermarket vacuum gauge in the car reads where it should.
Woody75 (Denver)
22:28:48 10/26/21
Re: Aftermarket vacuum gauge in the car reads where it should.
Metacom
22:56:28 10/26/21
Ok, thats pretty much what we have then.
Woody75 (Denver)
08:27:18 10/27/21
Re: Ok, thats pretty much what we have then.
Metacom
14:23:56 10/27/21
Vacuum test details here that Metacom refers to>>>>>>>>
ZUL8TR
04:36:34 10/27/21
ECU was swapped out.
Woody75 (Denver)
22:27:20 10/26/21
Re: ECU was swapped out.
Metacom
14:22:08 10/27/21
Power balance test.
Woody75 (Denver)
14:51:14 10/27/21
Replace the VTC gears & solenoids, redo timing.
00:44:03 10/27/21
VTC gears tested good.
Woody75 (Denver)
11:01:56 10/28/21
Re: VTC gears tested good.
Metacom
13:59:01 10/28/21
Re: Re: VTC gears tested good.
Metacom
14:06:24 10/28/21
Wiring harness.
scorp997
15:33:23 10/28/21
I tested the harness from the ECU to each injector.
Woody75 (Denver)
15:55:38 10/28/21
Possibly fuel pump controller low or mid speed not
LitlElvis
11:54:18 10/27/21
Wouldnt that show in the fuel pressure readings? (n/m)
Woody75 (Denver)
14:40:46 10/27/21
Probably - wasn't sure if you were monitoring fuel pressure
LitlElvis
13:43:27 10/28/21
I said this too but Woody didn't believe me. (n/m)
00:20:35 10/28/21
Neither did Mike :) (n/m)
Woody75 (Denver)
09:47:01 10/28/21
Update: Put in different FPC, no change. (n/m)
Woody75 (Denver)
11:39:36 10/30/21
Check out this post from a Z31 owner, similar symptoms
Polishzx
00:09:53 10/28/21
After thinking over this for awhile I'm going to toss
Ghoztt (MD)
15:23:24 10/28/21
Does the car have an EGR valve? (n/m)
mrchips
07:23:38 10/30/21
Actually I just played with that this morning.
Woody75 (Denver)
11:41:27 10/30/21
Woody75 (Denver)
11:47:22 10/30/21
Did smoke test include the engine. Intake leak check. -
mrchips
06:38:07 10/31/21
Yes, smoke test from the intake tube.
Woody75 (Denver)
11:03:11 10/31/21
Your symptoms sound similar to what I've been
black300zx
16:59:12 11/06/21
Another update:
Woody75 (Denver)
09:27:47 11/08/21
Brutal... Could you try testing fuel pressure in some other
Polishzx
02:05:39 11/09/21
