TwinTurbo.NET: Nissan 300ZX forum - Re: P drain is a pain but it can be solved with testing>>>>>>
Subject Re: P drain is a pain but it can be solved with testing>>>>>>
Posted by CMH on October 30, 2021 at 2:50 AM
  This message has been viewed 389 times.
In Reply To P drain is a pain but it can be solved with testing>>>>>> posted by ZUL8TR on October 29, 2021 at 04:09 AM
Message Thanks so much for your time and the reply. The measured voltage across (+) and (-) posts is 12.6V at idle around 750-800rpm. Since I am able to detect a bit of alternating current (0.5mV) at idle as well and came up with no appreciable change in amperage drawn on removal of all the fuses and fusible links, I’m going to assume it’s the alternator. I didn’t pull any relays - would it be best to do this as well?
