TwinTurbo.NET: Nissan 300ZX forum - Re: ECU was swapped out.
Subject Re: ECU was swapped out.
Posted by Metacom on October 27, 2021 at 2:22 PM
  This message has been viewed 294 times.
In Reply To ECU was swapped out. posted by Woody75 (Denver) on October 26, 2021 at 10:27 PM
Message How are the results of the cylinder power balance test to check if combustion effort is near equal across all 6?
If you really wanna get into it you can also run a relative compression test if you have a scan tool capable or oscilloscope to check for a weak cylinder, this test is different from a max compression reading through a regular compression test.
Have you tried wiggling through the EGI harness with engine running to see if the condition worsens or improves?
