TwinTurbo.NET: Nissan 300ZX forum - Now I'm interested in the outcome
Subject Now I'm interested in the outcome
Posted by Cjw3 on October 20, 2021 at 6:59 AM
  This message has been viewed 238 times.
In Reply To Re: Re: A.C.C. valve test posted by wjw300tt on October 19, 2021 at 07:44 PM
Message I can not understand any scenario, where an Idle Speed Control Valve Electrical Malfunction, Providing otherwise stable engine idle speed control, would malfunction and cause the engine to stall.
If the Nissan Books says it, then I agree, you might be tempted to chase down that path. And for that aspect I'm interested to learn your outcome of this Troubleshooting exercise.
I like to learn from other peoples trials on fixing things. That is what this forum is all about.
I have learned that the Book is wrong sometimes. Example. It states that Idle Fuel Mixture Control is an Open Loop Control. IT IS NOT. It is closed loop. I and others have proved it. I've watched it control, and I've played with the ECU registers and had it change it's Idle Mixture control points.
Good luck on your hunt, I'd like to learn what you find..
Cj
