TwinTurbo.NET: Nissan 300ZX forum - If your compression numbers are all within that range,
Subject If your compression numbers are all within that range,
Posted by Woodnutz (PA) on October 18, 2021 at 7:40 AM
  This message has been viewed 284 times.
In Reply To Would it be okay to raise boost? posted by 93TTZ5401 on October 15, 2021 at 06:44 PM
Message you're not in bad shape. From what I understand, consistency is the more improtant indicator. I'm currently at 14-15psi, depending on ambient temp and my compression numbers were just a bit higher than yours and the car runs like a dream.
Just stay on the lookout for misfires (I had a sketchy injector - replaced old-style with new-style from Bernie to resolve), and be sure you're not on original fuel damper and pressure regulator. Also, I definitely echo itsa300zx's point regarding a tune... gotta make sure you're set up as to not run the risk of running lean.
- Aaron
