TwinTurbo.NET: Nissan 300ZX forum - The gears allow for fine tune leveling only, beam pattern is
Subject The gears allow for fine tune leveling only, beam pattern is
Posted by Bernie (NoVA) on October 11, 2021 at 6:37 PM
  This message has been viewed 450 times.
In Reply To Adjusting JDM Xenon Headlights posted by ABNRMLZ on October 05, 2021 at 01:05 AM
Message not adjustable. They are designed for RHD use and the deflector shield is a fixed part inside the housing.
If you want to change the cut off pattern to LHD you need to open the lights and modify the cut off shield. And before you ask NO you can not use a halogen LHD shield, they are different as well. I have personally done this to my own set.
Some links / details here.
[ http://www.twinturbo.net/net/viewmsg.aspx?forum=general&msg_id=2495921 ]
[ http://www.twinturbo.net/nissan/300zx/forums/technical/view/881894/Modifying-the-99-Jspec-HID-for-LHD.html ]
