TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Re: help with 93 tt CAS 5v reference circuit problem
Subject Re: Re: Re: help with 93 tt CAS 5v reference circuit problem
Posted by itsa300zx on October 08, 2021 at 3:20 PM
  This message has been viewed 337 times.
In Reply To Re: Re: help with 93 tt CAS 5v reference circuit problem posted by Redpearl93tt on October 08, 2021 at 03:04 PM
Message If all 4 wires have good continuity between the CAS connector and ECU connectors, then I'd lean towards a faulty ECU or the connections.
Since the wires for the CAS are near the ends of the ECU harness; Be absolutely sure the harness connector is seated full into the ECU.
