TwinTurbo.NET: Nissan 300ZX forum - Walbro 350lph
Subject Walbro 350lph
Posted by Mike@ZSpeed on September 25, 2021 at 8:03 AM
  This message has been viewed 290 times.
Message Anyone running running Walbro 350lph on their Flex Fuel or E85 set-up?
Think my fuel pump is going & deciding either to go Walbro or OEM.
Regardless if its going or not Im going to replace due to its age.
** I have heard many people go years on FF or E85 with an OEM FP and not have issues like the FP constantly running.
If you have a Walbro 350lph:
1. Did you have any issues with the FPC ? Did your Walbro 350lph work as it should ( 2 ses. On then off )
2. Did you have to bypass the FPC?
3. Did you bypass the FPC & would your pump work properly ( 2 secs. on then turn off )
4. Did you bypass the FPC & the FP would constantly run?
5. Did you have to bypass the FPC & need to use an AFPR because the FP was constantly running?
1990 NA
1993 TT
