TwinTurbo.NET: Nissan 300ZX forum - Make sure the alignment tool goes all the way into the pilot
Subject Make sure the alignment tool goes all the way into the pilot
Posted by Ted (92TT) on September 15, 2021 at 1:16 AM
  This message has been viewed 339 times.
In Reply To transmission will not go in posted by Unicuma on September 14, 2021 at 11:00 PM
Message bearing before you final tighten the pressure plate bolts. If it's not seated all the way into the bearing the input shaft will never line up. Tighten the pressure plate a little at a time and make sure the alignment tool doesn't slip out of the bearing.
If you're using a needle bearing like the Nismo, your alignment needs to be perfect when you stab the tranny or you will destroy the bearing. It only takes a little off center bump to dislodge the needles. A bushing, on the other hand, is much more forgiving of installation abuse.
