TwinTurbo.NET: Nissan 300ZX forum - transmission will not go in
Subject transmission will not go in
Posted by Unicuma on September 14, 2021 at 11:00 PM
  This message has been viewed 470 times.
Message Hello all, I am doing a 5 speed swap on my 93. I have it all ready. I have replaced the pilot bearing, clutch, flywheel, pressure plate, throwout bearing and clutch fork. I install the flywheel, clutch and pressure plate with the alignment tool and its fine. But when I go to put the transmission in it wont go all the way in. Its about an inch from being all the way in. The input shaft goes through the clutch teeth then gets stuck a bit after. I have tried 2 OEM pilot bearings, and the NISMO one from Z1. But it still will not go all the way in. Please help ive been stuck for 3 days.
