TwinTurbo.NET: Nissan 300ZX forum - Burp it and make sure to use AF/water mix...
Subject Burp it and make sure to use AF/water mix...
Posted by Ted (92TT) on August 24, 2021 at 3:00 PM
  This message has been viewed 283 times.
In Reply To Cooling Gauge fine while driving then overheats after restar posted by sandisc on August 22, 2021 at 07:00 PM
Message You may be getting steam in the upper pipe after it sits hot for a while. Then it cools when liquid start flowing again. To burp it, put the front higher than the back and run it a few minutes cold without the radiator cap. Once the thermostat opens and all the air bubbles stop coming up, refill and cap it. Then let the overflow suction do its thing like LitlElvis said.
