TwinTurbo.NET: Nissan 300ZX forum - Thanks, made sense but it didn’t solve the problem. But
Subject Thanks, made sense but it didn’t solve the problem. But
Posted by doug8867 on July 28, 2021 at 5:40 PM
  This message has been viewed 260 times.
In Reply To Try simple first- check/clean battery posts and clamps. posted by Agent X on July 25, 2021 at 09:14 AM
Message The car did start again when I tried it on the first try. I noticed the aux fan came on like the car was hot. I let it run for several minutes, turned it off, then tried to retry it. I got nothing but the dash lights come on. No click, no sound, no nothing.
I waited for several minutes then tried again. This time, I heard the hum of what I assume is the fuel pump priming, lights on dash, but still no start. So it was a little different than what happened several minutes earlier.
Based on what has transpired, I would bet that if I try to start it tomorrow it may start again after it has been shut down for awhile.
Also, prior to all this I disconnected the radio to take it out of the equation.
The fan coming on right away after the car hadn’t been started in days is a bit puzzling. But the fact that it starts, then doesn’t, then does, then doesn’t, then does, then doesn’t is something I haven’t experienced before.
Note, I’ve replaced the PTU and the coolant temperature sensor in the past.
Still at a bit of a loss..
