TwinTurbo.NET: Nissan 300ZX forum - Well it can’t be air or compression so…
Subject Well it can’t be air or compression so…
Posted by ConVerTT on July 16, 2021 at 9:31 AM
  This message has been viewed 275 times.
In Reply To Re: Completely random throttle cut-out posted by Cjw3 on July 14, 2021 at 07:07 AM
Message It must be fuel or spark. Makes me think the problem is electrical - either a sensor or at your connections. If you make me guess: check / clean connectors for corrosion (injectors, TPS, CAS, PTU, MAF) , check TPS and go from there….
Any codes?
Old Yeller - 90 Slicktop NA (TT swap in progress) (PGY)
CRPTT - 91 "factory" 2+0 TT (cherry red)
RedZedII - 90 "factory" 2+0 TT, 10k miles - SOLD
RedZed - 90 "factory" 2+0 TT - SOLD
