TwinTurbo.NET: Nissan 300ZX forum - FPCU Wide Open Throttle question
Subject FPCU Wide Open Throttle question
Posted by Captconan on July 03, 2021 at 1:27 PM
  This message has been viewed 267 times.
Message When going WOT, does the ECU "signal" on the B/P 104 pin pull down to ground or pull up to some voltage? Looking at using this wire to activate an aux relay to supplement the higher current demands of larger fuel pumps that the transistors of the stock FPCU can't handle.
-Thanks
