TwinTurbo.NET: Nissan 300ZX forum - Might want to start thinking about an ECU connection issue
Polishzx
on June 30, 2021 at 1:53 AM
New everything won't start
posted by aztec300z
on June 23, 2021 at 02:03 AM
You got a completely new engine harness? If you had to de-pin and re-pin the smaller ECU connector, might want to double-check that. CAS connector, coolant temp sensor/connector, MAF connector also come to mind.
aztec300z
02:03:38 06/23/21
What about the clutch safety start button? There is a >>
ZUL8TR
12:37:21 06/23/21
Re: What about the clutch safety start button? There is a >>
aztec300z
14:06:35 06/23/21
FYI, the starter relay is an easy, cheap (less than $20) one
Woodnutz (PA)
09:45:31 06/24/21
Re: FYI, the starter relay is an easy, cheap (less than $20) one
aztec300z
00:19:58 06/25/21
New starter relay
aztec300z
19:02:19 06/26/21
aztec300z
21:46:02 06/24/21
Might want to start thinking about an ECU connection issue -
Polishzx
01:53:00 06/30/21
