TwinTurbo.NET: Nissan 300ZX forum - What about the clutch safety start button? There is a >>
Subject What about the clutch safety start button? There is a >>
Posted by ZUL8TR on June 23, 2021 at 12:37 PM
  This message has been viewed 275 times.
In Reply To New everything won't start posted by aztec300z on June 23, 2021 at 02:03 AM
Message plastic cap on the switch on the clutch pad lever if missing, they crack with age and break off, and will not start with the clutch depressed. What about the theft protection system that will prevent start if issues with that system?
The fact that you can do a getto jump to the starter Bendix solenoid from battery with success indicates there is a issue with start circuits between ignition switch and starter Bendix.
Maybe bad cable to starter Bendix unit?
Maybe bad ignition switch on column?
I have come across bad relays that test OK for continuity but fail with amperage load, maybe your starter relay is bad? I have had my Z starter solenoid test OK and not carry the amps, replaced relay and ok.
ZUL8TR
