TwinTurbo.NET: Nissan 300ZX forum - That's interesting, if the main seal was leaking though it
Subject That's interesting, if the main seal was leaking though it
Posted by Adamo on June 09, 2021 at 12:27 PM
  This message has been viewed 244 times.
In Reply To Oil leak out the weep hole of the trasmision ... posted by JMartz on June 08, 2021 at 07:53 AM
Message The oil would be visible where? I'm assuming for my case the rear main seal isn't at fault cause it looks dry around it. But it's still good info to have so thank you!
Would a rear main seal leak somehow make it into transmission housing without oil getting on flywheel or clutch assembly?
The confusion I'm having is that since it seems to be the halfmoon leaking, why is there a lot of oil in the transmission casing but none at the bottom of the oil pan. I feel like it should make it's way down to the oil pan, unless the steel plate between the transmission and engine stop that from happening
