TwinTurbo.NET: Nissan 300ZX forum - Re: Potential issues running larger fuel pump?
Subject Re: Potential issues running larger fuel pump?
Posted by Rob260 on May 24, 2021 at 8:38 PM
  This message has been viewed 281 times.
In Reply To Potential issues running larger fuel pump? posted by Buckaroo Banzai on May 22, 2021 at 05:09 PM
Message I don't know what the theoretical limit of 5/16" tube is but turbosmart use that size on their 800hp regs so I think you'd be OK.
From experience yes you'll need an aftermarket fuel pressure regulator.
You would only need to go larger if you can't reduce fuel pressure sufficiently.
