TwinTurbo.NET: Nissan 300ZX forum - I agree that the stock fuel lines will have the potential
Subject I agree that the stock fuel lines will have the potential
Posted by LitlElvis on May 22, 2021 at 8:47 PM
  This message has been viewed 329 times.
In Reply To Potential issues running larger fuel pump? posted by Buckaroo Banzai on May 22, 2021 at 05:09 PM
Message to not flow the volume of fuel that the pumps you mentioned are capable of delivering. An aftermarket higher flowing FPR will be necessary, but its ability to control rail pressure will likely be limited by the factory return line size.
I'm not sure if the OE TT fuel pump controller will be able to work with those fuel pump's power requirements, but even if you plan to delete the FPC, you will need to up-size the power and ground wires to handle the max amperage those pumps will pull at the max pressure you intend to use.
