TwinTurbo.NET: Nissan 300ZX forum - What the difference in a 95’ harness compared to a 91?
Stanky (BC)
on May 01, 2021 at 7:05 PM
Possible. You might luck out and find a new 95 OEM
posted by MixManMash
on May 01, 2021 at 05:04 PM
Injectors and CAS connectors? Late model inj connectors would be nice but a quick CAS splice wouldn’t be a big deal if that’s all that’s different
Someone please help..before I torch this car :)
Stanky (BC)
17:01:52 04/30/21
andddd a new pump/ confirmed fuel pressure good... (n/m)
Stanky (BC)
17:05:25 04/30/21
My car developed a misfire a few years ago.
JMartz
17:17:20 04/30/21
This one seems pretty unlikely, but for S&G's, Pat, you can
Woodnutz (PA)
20:50:07 04/30/21
Ditto
megaDan
21:05:29 04/30/21
Although not very likely, you should check the
timz
18:42:04 04/30/21
He would have bypassed his fuel pump controller.
MixManMash
20:37:38 04/30/21
Check the injector sub harness to main harness connection
MixManMash
21:21:53 04/30/21
Also check that the ECU connector is seated properly and
MixManMash
21:23:24 04/30/21
Thanks for the responses guys
Stanky (BC)
09:45:39 05/01/21
Re: Someone please help..before I torch this car :)
93TTZ5401
22:00:05 04/30/21
lymon
23:27:20 04/30/21
Never even thought of this, but will check it out .. (n/m)
Stanky (BC)
09:58:07 05/01/21
data logs... anything from the Haltech?
vorpalZed
01:09:14 05/01/21
I will log stuff tomorrow, I also talked with seb
Stanky (BC)
15:19:44 05/01/21
MixManMash
17:04:40 05/01/21
What the difference in a 95’ harness compared to a 91? -
Stanky (BC)
19:05:46 05/01/21
CAS, injector and AC compressor connectors.
MixManMash
19:22:34 05/01/21
I havent seen any feedback yet on the Z1 EGI harness.
ZXoltan
10:26:33 05/04/21
Hmm thats a weird one.
Drk93TT
06:12:30 05/01/21
So, in addition to my suggestions above, I think it's time
MixManMash
08:24:10 05/01/21
... or... time for that 2J swap. (n/m)
Woodnutz (PA)
22:04:16 05/01/21
LS is a better answer. (n/m)
MixManMash
23:41:08 05/01/21
Blasphemer (n/m)
Zeus
13:40:06 05/04/21
Appears 1 and 3 not firing. 5 is. Load test ptu switched
mrchips
07:47:18 05/03/21
You should recount your timing belt cogs. ;-) (n/m)
MeatMan (604Z)
13:30:31 05/07/21
