TwinTurbo.NET: Nissan 300ZX forum - I know a Bad TPS will kill the Engine..
Cjw3
on April 07, 2021 at 7:47 PM
fuel injection and TPS question
posted by slcZ32
on April 07, 2021 at 07:13 PM
The Fuel pump will only run while cranking, or the CAS is turning.. It should not 'Drop' in pressure when the Fuel Pump Stops.. It will slowly fall.. Sometimes Hours.. Sometimes Days.. I had one hold pressure for a week!.. But hours is good..
Cj
slcZ32
19:13:28 04/07/21
I know a Bad TPS will kill the Engine.. -
Cjw3
19:47:59 04/07/21
Re: I know a Bad TPS will kill the Engine..
slcZ32
22:09:32 04/07/21
You have pressure during cranking.. Its fine
Cjw3
07:03:29 04/08/21
slcZ32
11:39:25 04/08/21
Well... Cranks no start, I have fuel, spark, injectors good
slcZ32
11:50:01 04/08/21
you have spark.. needs fuel then
Cjw3
07:19:47 04/09/21
Re: you have spark.. needs fuel then
slcZ32
15:27:54 04/10/21
If it's big enough (n/m)
Cjw3
22:26:21 04/10/21
Re: If it's big enough
slcZ32
18:03:30 04/11/21
I'm not a TT guy, but that seems low
Cjw3
20:11:33 04/11/21
Re: I'm not a TT guy, but that seems low
slcZ32
15:40:24 04/15/21
