TwinTurbo.NET: Nissan 300ZX forum - I did an R134A conversion
Subject I did an R134A conversion
Posted by megaDan on March 25, 2021 at 10:20 AM
  This message has been viewed 384 times.
In Reply To Do you have details for your R12 -----> R134a convert? (n/m) posted by ZUL8TR on March 22, 2021 at 05:51 AM
Message After living without AC for 10 years, I finally decided to do some diagnostic work and installed the high/low port adapters and hooked up my manifold gages. (all o-rings were replaced last time the motor was out just in case) I discovered a leak in the condenser, and searched high and low for a replacement. I finally found one in a junkyard in NC, but it was from a 90-93 (R12 design). I installed that along with a new dryer, and drained the compressor of oil per the Z32 wiki....I don't recall if I refilled with new oil or not.
https://conceptzperformance.com/wiki/index.php/R134A_Conversion
Anyway. The air is still plenty cold despite having a less efficient condenser, but I haven't used it much either. Hopefully this information helps even a little bit.
