TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Procedure for testing hydraulic lifters?
Subject Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Procedure for testing hydraulic lifters?
Posted by DanielThomas on February 25, 2021 at 1:54 PM
  This message has been viewed 232 times.
In Reply To Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Procedure for testing hydraulic lifters? posted by DanielThomas on February 22, 2021 at 03:00 PM
Message Valves are fine, Piston is fine. Belt obviously never jumped
Tonnes of metal flakes in the bottom end.. and a few have left small scratches in the bore, not bad i cannot feel it with my fingernail im just going to use it as it..
As for why a compression test showed 0 psi on the whole bank, i have no clue, maybe my 2.2mm cometic gasket failed but held pressure below 100PSI for the leakdown test.
Just hoping its the main bearings/rod bearings and not the actual rod bearings as they were brand new with the pistons and from what i understand not replaceable
