TwinTurbo.NET: Nissan 300ZX forum - 0 PSI on LHS cylinder bank?
Subject 0 PSI on LHS cylinder bank?
Posted by DanielThomas on February 23, 2021 at 4:01 PM
  This message has been viewed 279 times.
Message Does anyone know what could cause 0 PSI on one cylinder bank? its a fresh forged motor with less than 50 miles on it.
The head gasket is not leaking
The engine is definitely timed properly now, but may have slipped previously due to a collapsed tensioner
The engine is knocking in the cylinder head somewhere so I expect to find damaged valves, but could a slipped exhaust cam damage all six valves? I can see the intake ones and they are all OK.
Even weirder, it holds at 15% leakage on a leakdown test, but i thought it should be 0 since the compression readings are zero
Confused.com
