TwinTurbo.NET: Nissan 300ZX forum - Fuel leak need help!
Subject Fuel leak need help!
Posted by TwinTumor on February 07, 2021 at 12:49 AM
  This message has been viewed 307 times.
Message hey fellas quick question for you guys. I found the hose between the two fuel rails was leaking fuel, would that cause the Z not to start? It was spraying out, there was also fuel on the top of the black insulator, anyways would a fuel leak at the rail, which would create low pressure cause a Z not to start, also would it cause the Z to buck under load?
