TwinTurbo.NET: Nissan 300ZX forum - Ignition switch
Subject Ignition switch
Posted by JaredLopeZ on January 17, 2021 at 9:20 AM
  This message has been viewed 311 times.
Message Can’t seem to find this answer anywhere. I have looked. I have an issue where if my battery is connected the car is always on. As if the key is in and turned all the way just before starting the car. The radio is on, the a/c blows all the dash lights are on etc. this is all without the key in the ignition. If I start my Z I cannot turn it off by removing the key. I have to pull
The fuel pump relay for the car to shut off. Then disconnect the battery so it doesn’t drain. As you can imagine this is very inconvenient. I have determined it’s very likely my ignition switch( unless someone has other ideas). I want to replace it but I have plans to eventually convert my TT to a 5 speed but not for a year or two. It I change the ignition switch, can I get away with replaced it with the standard ignition switch instead of an auto. Would rather not have to source/ buy the part twice.
