TwinTurbo.NET: Nissan 300ZX forum - Traced it to IC621
Subject Traced it to IC621
Posted by freak152000 on January 02, 2021 at 7:02 PM
  This message has been viewed 280 times.
In Reply To Re: EGI relay and .75A current draw w/ key on posted by Cjw3 on December 31, 2020 at 05:22 PM
Message So pin 16 go is activated through Diode D681 which is then switched by IC621, PN: UPA1558H. The closest data sheet I could find for it is: https://pdf1.alldatasheet.com/datasheet-pdf/view/6552/NEC/UPA1556AH.html
How ever there are no outward signs of damage. So it could still be an issue. Unfortunately I don't have a spare ECU to test with. It should also be noted that I checked ground isolation on the control wire (pin 16) and it is fine with no continuity to ground.
