TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Coolant Temperature Gauges and headlight not working
Subject Re: Re: Coolant Temperature Gauges and headlight not working
Posted by TTwinTTurboZ on December 19, 2020 at 11:25 PM
  This message has been viewed 309 times.
In Reply To Re: Coolant Temperature Gauges and headlight not working posted by JULIAN on December 14, 2020 at 02:56 PM
Message Hello, so it appears that the stock one isn't installed anymore. I am going to order the AEM one that is installed right now and not giving a reading. There is just lines on my pillar gauge. Here are some pics of where it attaches to and also where I would think the stock connector is, but it doesn't attach to a stock coolant temp sensor, I tried two different ones. Im hoping someone can confirm this part picture from AEM is the same one that I have. I used a millimeter to test the aem coolant sensor and it doesn't give me the same readings as the ones that are mentioned on tt.net, but that is for stock sensor. The overall readings were way higher than normal...for example cold water was reading like 10-12 on the 20k setting on the multimeter and close to boiling only dropped to 2-3. The write-up mentioned that it should be down to like .3 or something, I have to go back and check it. Anyways, just an update
https://ibb.co/RSTcLqS
https://ibb.co/2sV6HPZ
https://ibb.co/N7QTRz2
IMG-8315
IMG-8318
IMG-8319
