TwinTurbo.NET: Nissan 300ZX forum - update!! Injectors on passenger side not clicking
Subject update!! Injectors on passenger side not clicking
Posted by slcZ32 on December 14, 2020 at 9:17 PM
  This message has been viewed 321 times.
In Reply To whats the correct vacuum at idle for a tt? posted by slcZ32 on December 10, 2020 at 05:43 PM
I checked for resistance on all injectors and got 10.4 ohms. So, then i pulled the cas and noticed that the injectors on the passenger bank wont click and, that the injectors on the driver side would click with a weak click.
I did a continuity test from the ECU connector using pin 58 as my common and the injector pins. They all came back with a 10.4-ohm resistance.
I did the CAS test from the FSM and it fluctuates between 0 to 5v. However, it doesnt seem to go back down to zero volts when I stop spinning the cas. It sits at around .20 V.
What are your thoughts?
