TwinTurbo.NET: Nissan 300ZX forum - You more than likely have a vacuum leak >>>>>>>
JULIAN
on December 14, 2020 at 7:40 AM
Re: I thought I remember reading normal is about 18 to 20 Hg.
posted by slcZ32
on December 13, 2020 at 12:15 AM
Mine is currently the same reading as yours and I performed a smoke test and found that my upper intake manifold plenum gasket is leaking. So I might as well upgrade my injectors to larger ones, etc. at the same time.
whats the correct vacuum at idle for a tt?
slcZ32
17:43:06 12/10/20
You need to check vacuum signal with a simple vacuum gage>>
ZUL8TR
09:08:37 12/11/20
Depends on your elevation too, 2200ft can drop a couple "Hg
itsa300zx
09:58:22 12/11/20
Good point, living at sea level I forgot that ;-) >>>>>>
ZUL8TR
13:44:24 12/11/20
JULIAN
22:48:12 12/11/20
slcZ32
00:15:51 12/13/20
You more than likely have a vacuum leak >>>>>>> -
JULIAN
07:40:20 12/14/20
Please watch this video and tell me if my ECU is fried.
slcZ32
00:21:13 12/13/20
Have you tried >>>>
JULIAN
13:03:45 12/14/20
When you clean the connectors put some dielectric grease >>
ZUL8TR
15:06:44 12/14/20
Re: Have you tried >>>>
slcZ32
21:15:01 12/14/20
update!! Injectors on passenger side not clicking
slcZ32
21:17:50 12/14/20
Re: update!! Injectors on passenger side not clicking
mrchips
07:45:58 12/18/20
