TwinTurbo.NET: Nissan 300ZX forum - Re: Oil pan dent
Subject Re: Oil pan dent
Posted by Ted (92TT) on November 24, 2020 at 11:15 AM
  This message has been viewed 283 times.
In Reply To Oil pan dent posted by Ca1ge on November 24, 2020 at 10:45 AM
Message I've never heard of that, and I suspect it was a joke. A hole would certainly keep the oil flowing--right out of the pan and all over the ground. Maybe someone will correct me. In any case, once you remove the dent you should be okay, assuming it wasn't driven hard on low oil pressure and scuffed a ring or a journal bearing. There's really nothing that will dent the pan short of running over something big. It was most likely sitting on the pan while out of the car. This is common with JDM engines or sketchy mechanics.
