TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Re: Re: Z is cutting out and won't start
Subject Re: Re: Re: Re: Z is cutting out and won't start
Posted by TwinTumor on November 19, 2020 at 12:41 PM
  This message has been viewed 290 times.
In Reply To Re: Re: Re: Z is cutting out and won't start posted by itsa300zx on November 19, 2020 at 12:19 PM
Message When the car was running on the way home, it would idle perfectly fine. So I don't think its the PTU or CAS, I checked all the connectors and they are fine. Timing is good. My guess is bad fuel regulator, bad fuel pump, or clogged fuel filter or maybe a leak in fuel lines somewhere. I don't think the fuel dampener would cause it not to start. So pretty much, the car will IDLE FINE if I push start it, and it buckles and hesitates when I give it gas. Almost feels like I'm hitting redline, and the tachometer will be bouncy. I checked codes and got nothing... I don't think its the injectors because I have a 95 with the later style. Has anyone had fuel regulator or pump issues?
