TwinTurbo.NET: Nissan 300ZX forum - My guess was that Nissan designed the extra upper bleeding
Subject My guess was that Nissan designed the extra upper bleeding
Posted by robo (sebring1970) on November 13, 2020 at 11:59 PM
  This message has been viewed 363 times.
In Reply To I did the upper clutch bleed line delete on my car using posted by Inzane on November 13, 2020 at 12:20 PM
Message point and tube as a way to allow air bubbles to rise (?) which in theory would make bleeding easier. Even though the Nissan engineers know more in their little fingers than I do in my brain, I think the upper bleeding point may be another (minor) example of Nissan 90's over-engineering.
When your look at the 3-way junction box where the bleeding tubes intersect, and the right angles of flow, to me a straight shot made much more sense. My real motivation at the time was the upper bleeding point was hitting the underside of my hood and making a rattle. Bleeding was a breeze after the delete and I never had an issue. All the comments about improved clutch feel in my write up on my Web site were probably my wishful imagination since I had just changed my clutch at the same time. But the part about never having a problem was true. And Inzane lists his occupation as "Professional Engineer" so that beats a blank
"Straight-line acceleration is probably the first aspect of
automotive performance that any intelligent driver gets bored with."
Peter Gregg
"We owe a lot to the dragsters.
They always break something,
figure out a way to beef up the part
and then the benefit trickles
down."
Robo
"Not everything that can be counted counts. Not everything that
counts can be counted."
Einstein
