TwinTurbo.NET: Nissan 300ZX forum - Belt systems are designed to move teeth
Subject Belt systems are designed to move teeth
Posted by Dallas DamonZ on November 04, 2020 at 2:15 PM
  This message has been viewed 297 times.
In Reply To 120k Timing Belt Tensioning Procedure posted by Rossm952 on November 04, 2020 at 09:56 AM
Message You would likely have to put a LOT of revolutions to get the dots to line up again. It's not an every 2 turns thing. Pretty sure there are an odd number of teeth on the belt to cause it to 'walk' so the belt doesn't constantly contact the same place on the sprockets frequently.
Turning 720 is to make sure nothing is hitting inside the engine and for the tensioner to find it's normal extension. Check the plunger measurement, get it in spec and you should be OK.
Later
Click here to e-mail me! Click here for Twin Turbo Zs of Dallas!
When was the last time you *really* did something with your Z to call
yourself a Z enthusiast?
Member #1 PETZ
