TwinTurbo.NET: Nissan 300ZX forum - Machine shop went crazy! need help
Subject Machine shop went crazy! need help
Posted by DanielThomas on November 03, 2020 at 4:10 AM
  This message has been viewed 437 times.
Message Hi guys
I had a machine shop take 0.011 / 0.3mm from my engine block
and 0.0354331 / 0.9mm from my cylinder heads
So i have lost 1.2mm / 0.047 of material in total.
Iv'e compensated for the block already by buying a 1.5mm tomei head gasket, and i have bought adjustable BDE bullseye gears, the block was also bored to 88MM with CP pistons.
Am i going to be OK, or will i need to purchase adjustable intake gears too? i don't really have an option for those as im using normal 93 stock auto cams, i haven't the knowledge to work out what my compression ratio will be either
I have no clue how to setup the gears i have purchased either, would i need to set them to full advance or full retard?
I will as a token of apprechiation send 100 dollars on paypal to whoever replies and is able to fully help me work out my compression ratios and any other problems i may run into to put my mind and rest and fix this mess to make sure i don't screw my car!
-Daniel
