TwinTurbo.NET: Nissan 300ZX forum - So, I would recommend not just blindly turning up the boost.
Subject So, I would recommend not just blindly turning up the boost.
Posted by MixManMash on October 26, 2020 at 3:24 PM
  This message has been viewed 380 times.
In Reply To Time to turn up the boost? HKS 2530 posted by down5hift-2 on October 26, 2020 at 08:35 AM
Message I would do the 6Ps La-Z-Link
That's just to check the over all health.
Second, the SAFC might be there because it has dual MAFs. The SAFC would take the signal from 2 MAFs and convert it to a single signal that the ECU can read. You'd need to check the settings on it to see if it is summing (which means you have a single pop chip) or averaging (which means you have a dual pop chip).
Finally, before just blindly turning up the boost, find a reputable tuner and get it dyno tuned properly for the fuel you will be running. This will ensure you are running it safely.
