TwinTurbo.NET: Nissan 300ZX forum - Were the tires at least matched mounted? That is the >>>
Subject Were the tires at least matched mounted? That is the >>>
Posted by ZUL8TR on October 16, 2020 at 4:24 AM
  This message has been viewed 379 times.
In Reply To Vibration Mystery posted by JMartz on October 15, 2020 at 09:08 AM
Message correct placement of the factory determined harmonic dynamic colored dot on the tire to the correct radial runout position on the rim. Rim should have a radial runout mark that can be measured and match mounted to the harmonic dynamic colored dot on the tire. All performance tires are harmonic dynamic run and marked at the factory. Performance rims also are marked to locate the radial mark to match mount the tire to.
Most shops not in the know align the tire dot to where the air valve is as a quick assembly - not usually correct.
Forced road balance is certainly a way to help but match mounting will go a long way to aid in that process.
As a quick look jack up the tire and at least see if it rotates without excessive radial out of round. Any out of round on the tire should be minimal see manual below.
Details on runout and other suspension checks here:
[ http://300zx-twinturbo.com/cgi-bin/manual.cgi?list=fa ]
ZUL8TR
