TwinTurbo.NET: Nissan 300ZX forum - Repurposing the dash boost gauge
Subject Repurposing the dash boost gauge
Posted by madkiwi on October 15, 2020 at 1:28 PM
  This message has been viewed 408 times.
Message I have an Auto Meter pillar mounted boost gauge, obviously more useful/accurate than the cluster gauge so I was wondering if there is any harm in connecting the factory gauge to something else?
Specifically I want to have some idea of what the EGR system is doing so I was thinking of disconnecting the factory gauge from the balance tube and teeing it into the hose that goes from the EGR solenoid to the EGR valve. That way I will be able to observe the state of that system- is it at zero when idling, vacuum when cruising, zero or under pressure at WOT.
Just wondering if the ECU is listening for input from the boost system, I do not see a wire for it in the ECU connector but I only do this for a hobby.
Thanks!
