TwinTurbo.NET: Nissan 300ZX forum - Removing compressor discharge hose to condenser
Subject Removing compressor discharge hose to condenser
Posted by robsheer on September 06, 2020 at 9:14 AM
  This message has been viewed 376 times.
Message I need to remove the AC discharge hose that runs from the compressor discharge port to the condenser to fix a leak in the hose. I removed the connection at the compressor side and the condenser side and the one bracket that holds the aluminum tube to the frame, but the hose/tube will not come out. Seems to be stuck on something. Do I have to remove the radiator or bumber to get it out? Has anyone removed it with minimum teardown? It's a 1994 300zx NA stock, no mods. Thank you!
