TwinTurbo.NET: Nissan 300ZX forum - I had similar problems with my 96 NA...
Subject I had similar problems with my 96 NA...
Posted by Metacom on August 25, 2020 at 9:04 PM
  This message has been viewed 375 times.
In Reply To Calling all experts... car idles rough, hesitates/stumbles posted by theo.laz on August 25, 2020 at 01:54 AM
Message Where in I threw the book at it and followed every relevant diag with every check coming up as OK like you have. Eventually I had to replace the timing belt for maintenance and it resolved the rough idle / misfire at idle. But it was previously replaced by someone else who I believe installed the belt to the cams/crank just ever so slightly off as to cause the issue.
Have you tried a vacuum test? They're quick, easy, and tell a lot.
How about swapping in a known good OE ECU?
