TwinTurbo.NET: Nissan 300ZX forum - Where is the smoke coming from? If from the small hole in
Subject Where is the smoke coming from? If from the small hole in
Posted by LitlElvis on August 18, 2020 at 11:17 AM
  This message has been viewed 316 times.
In Reply To Driver side recirc. valve leaking. posted by Tanley (ATL) on August 16, 2020 at 09:11 AM
Message the casting under the diaphragm cap, this may be normal due to a small amount of pressure escaping past the internal guide and valve stem into this cavity. It would not be normal if a large volume of air is escaping through this hole, which would indicate a ruptured diaphragm.
